IP not registering with Call Manger
Cleo Jamison
I'm running Call Manger 11.0
I have a new 7962 phone that will not registered.  If i configure Call Manager to auto-register the phone I get a security error on the phone. If I try to configure the phone manually I get a DBconfig error on the phone.
Please help.
-##I don't recall if 7962 is supported in ccm 11. Check that in reporting.
If so, clear ITL file on the phone and retry
We have 7962 currently running in version.
CUCM didn't start deprecating phones until 11.5, if you're on 11.0 you'll get all the phone models.
java
if this helps, please rate
M02@rt37
Hi @Cleo Jamison
Try a factory reset for your 7962.
Best regards
