9965
Martin Marino
Beginner
IP Phone 3905 - UCL License
Hi! I would like to know which UCL License is needed for phone 3905. Is it the UCL Basic License?
Thks!
Martin
9 REPLIES 9
Rob Huffman
Hall of Fame Community Legend
Hi Martin,
The 3905 actually falls into the "Essential" catagory (although not shown in this doc );
License Types
License Type Descriptions
Enhanced This license type covers a user and the user’s primary phone when the system
classifies the primary phone as enhanced.
• The Cisco Unified IP Phone 6941 and Cisco Unified IP Phone 6961 use an
enhanced license if these phones are not set up as public space phones or
adjunct phones.
• The Cisco IP Communicator or Cisco Unified Client Services Framework use
this license type if it is the primary phone for the user.
• The Cisco Unified IP Phone 7937 uses this license type if it is the primary
phone for the user.
Basic This license type covers a user and the user’s primary phone when the system
characterizes the primary phone as basic. The Cisco Unified IP Phone 6921 and
Cisco Unified IP Phone 6911 use this license type if the basic license is available
and if the phone is not set up as an adjunct phone.
This basic license type allows a regular user (non-department user) to use
voicemail, Reach Me Anywhere, and Cisco Extension Mobility if the features are
enabled in the usage profile and supported on the phone model.
Essential This license type supports a user and the user’s phone when the system
characterizes the phone as essential. The Cisco Unified IP Phone 6901 and Cisco
VG224 Analog Voice Gateway fall into this category; for example, each analog port
on a Cisco VG224 Analog Voice Gateway consumes a unit in the license file.
Primary phones are not related to the analog/application only license type; that is,
each phone that is classified by the system as analog or application only uses one
license from this license type.
Adjunct Adjunct licenses are used for a secondary phone; that is, the user has a primary
phone assigned to him, and the user needs an additional phone. Adjunct licenses
apply to phones that are characterized by the system as of equal or lesser value than
the primary phone.
Voicemail This license type allows a regular user (non-department user) to use voicemail and
voicemail related features. A separate voicemail license is required for each regular
user (non-department user). For example, if you have 150 users that require
voicemail, you need 150 voicemail licenses.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe3k/8_6_1/system/01_license.html
Cheers!
Rob
Hi Rob,
I just wanted to consult about 6921 model. I find several contradictory documents that once claim a Basic license and once an Enhanced license for this specific model.
Can you advise?
thanks Elton
Elton, did 6921 work with Basic UCL for you?
-OJ
Hi Oj,
I can confirm 6921 requires definitely a basic license. On the other side I just become aware that basic or enhanced is just an artificial licensing term that Cisco is using, because in the real life they will convert again in a certain number  of the traditional Devoce License Units DLU that call manager has been always using as licensing units. This seems to he the case for at least 8.5 or 8.6 version. This is suposed to change at some later version.
So to cut short, Yes, buy a basic license for eacu 6921 and you will be ok even legally and technically.
Rgds,
Elton
Thanks for helpfuul reply, Elton.
hi rob !
the 3905 supports voice mail ?? is the essencial licensing enought for the 3905 with voice mail ??
regards
Javier
Rob Huffman
Hi Elton,
Hahahaha! Yes, another confusing Cisco Licensing question
The 6921 requires only a "basic" license unless the user also requires the use of the following
in which case the "enhanced" license is required.
Basic IP User License also entitles Mobile Connect for a user who does not have any mobile client
(dual mode or Cisco Unified Mobile Communicator)
Cheers!
Rob
Hello Rob,
I am also sailing in the same boat. Trying to find out the exact answer if 6921 will work with Basic UCL on CM 8.5 or higher.
have you seen that working in production?
REgarsd
-OJ
Andre Camillo
Contributor
Hello everyone,
Cisco has provided a very good and simple explanation to this matter, check out Figure 1 (on page 6) of BE6K's ordering guide:
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/be_6000.pdf
Create
Recognize Your Peers
Content for Community-Ad
