10-09-2023 09:01 AM - edited 10-12-2023 06:17 AM
I have Cisco 7911 IP phones that work internally, but I have other phones with the same model that can't pull their configuration file. What's the solution?
10-10-2023 07:26 AM
A few questions: What CUCM version (or CME) are you working with? When you say you 'can't pull their configuration file', what specifically are you attempting to do? Also, if I am reading your post right it seems you can pull the configuration file for one 7911 but not other? Or am I misunderstanding that?
Maren
10-12-2023 02:53 AM
First of all, thank you for your response. Indeed, as you explained, this is my problem. It actually works for me with the same model, but I also have more phones with the same model and they do not respond to the profile or cannot pull it.
-CME Version ( Cisco IOS Software, C2900 3.5.3 )
10-10-2023 07:28 AM
Is the phone pulling an IP address? If so, what do you see in the phone logs?
Is it authenticating on the network?
10-12-2023 02:56 AM
Thank you for your interest. It does take an IP address.
