03-26-2014 05:17 AM - edited 03-16-2019 10:15 PM
Hi Guys,
My Customer have the CUCM 8.6.2.22900-9 and perceived the following problem with IP Phone 7940: In the ring tones options, when to do test until position 29 it´s Ok, after then appear the message error: TFTP write error: file missing...
Any have idea about this?
The firmware in use is: P0030801SR02
03-26-2014 07:01 AM
Is this the only phone experiencing this issue?
Yosh
03-26-2014 07:13 AM
Hi Yosh,
Thanks a lot for your contact. Answering your question, no there are another IP Phone 7940 with the same problem.
Tanks,
Wilson
03-26-2014 12:15 PM
Probably not all the ringtones meet the requirements. You should probably chech that all of them meet the specifications listed below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsrings.html#wp1011548
Tere.
03-26-2014 12:32 PM
Hi Tere,
Thanks a lot for your contact. I read the documentation that You send for me, but, I don´t understand as verify the requirement. For example, as I saw the ring size
•Maximum ring size—16080 samples
•Minimum ring size—240 samples
As I saw the size the ring tone that was did upload in CUCM?
Wilson
