IP phone 8811 "Telephony Service Unavailable"
Hello Dears,
I have CME Version 12.0. All phones register without issues except one 8811 sip phone, it was working fine. After that i move it to another office it stopped working and show message "Telephony Service Unavailable".
kindly find the configuration below:
voice register pool  44
 busy-trigger-per-button 2
 id mac F8A5.C5A1.D510
 type 8811
 number 1 dn 44
 cor incoming mobile default
 dtmf-relay rtp-nte
 description Finance Mgr
 codec g711ulaw
voice register dn  44
 number 128
 call-forward b2bua noan 7*95632322 timeout 20
 allow watch
 pickup-call any-group
 name Finance Mgr
 label Finance Mgr
 voice service voip
 no cti shutdown
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 120 min 60
 voice register global
 mode cme
 source-address 192.168.60.50 port 5060
 no outbound-proxy
 max-dn 150
 max-pool 58
 load 7811 sip78xx.11-7-1-17.loads
 timezone 31
 date-format D/M/Y
 hold-alert
 url directory http://192.168.60.50/localdirectory
 tftp-path flash:
 file text
 create profile sync 5668633123163634
 network-locale GB
 user-locale U1 load CME-locale-en_GB-English-11.5.11.5.tar
 ntp-server 192.168.60.50 mode directedbroadcast
 auto-register
 telephony-service
 moh-file-buffer 9000
 no auto-reg-ephone
 authentication credential cue cue
 authentication credential admin cisco
 xml user cisco password cisco 15
 max-ephones 10
 max-dn 100 no-reg
 ip source-address 192.168.60.50 port 2000
 auto assign 1 to 39
 service directed-pickup gpickup
 url services http://192.168.60.51/voiceview/common/login.do
 url authentication http://192.168.60.50/CCMCIP/authenticate.asp
 load 7975 SCCP75.9-4-2SR3-1S
 time-zone 31
 time-format 24
 date-format dd-mm-yy
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern .T
 moh enable-g711 "flash:en_bacd_music_on_hold.wav"
 multicast moh 239.1.1.1 port 2000
 web admin system name cue password cue
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp 7960 Aug 05 2018 12:54:52
 Any suggestions ?
5 Replies 5
If the phone isn't in the same cme subnet, you need to enable authentice
register and assign username/pass to voice pool. Other than that share
debug ccsip mess
I'll get the logs and attache them here.
Thank you for your assistance.
Eric Ingram
Level 4
Level 4
you can try
under your voice register global add
authenticate realm all
unfortunately, that didn't work also.
Enable the following and collect the logs post a phone reset -
debug ccsip message
debug ccsip non-call
debug ccsip error
debug voice register events
debug voice register error
