IP Phone 8831 not registered
I have cisco IP Phone 8831 and router CME version 10.5
and here is that i have configured in my CME
voice register pool-type  8831
 phoneload-support
 num-lines 6
 description CISCO IP PHONE 8831
 reference-pooltype 6941
voice register global
 mode  cme
 source-address 192.168.100.1 port 5060
 max-dn 10
 max-pool 10
 load 6941 SIP69xx.9-4-1-3SR2
 load 8831 sip8831.9-3-3-5
 authenticate register
 authenticate realm cisco.com
 olsontimezone Asia/Jakarta version 2013d
 timezone 41
 time-format 24
 date-format D/M/Y
 tftp-path flash:
 file text
 create profile sync 0461204502605337
voice register dn  1
 number 2083
 allow watch
 name CONFERENCE ROOM
 label CONFERENCE ROOM
voice register pool  1
 busy-trigger-per-button 2
 id mac AC44.F212.A10F
 type 8831
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte sip-notify
 voice-class codec 2
 username cisco password cisco
but my IP Phone 8831 still not registered.. anybody help :(
Rocky
20 Replies 20
Can you please activate a debug ccsip message and debug voip register errors and post the output?
Carlo
Please rate all helpful posts "The more you help the more you learn"
this is the debug result
Oct 22 07:34:31.995: EVENT: 1 node in nonce tree obsolete
Oct 22 07:34:31.995: VOICE_REG_POOL: deleted key(2968B2890003A0BB) from nonce table
Oct 22 07:34:44.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:2000@192.168.100.1:5060 SIP/2.0Via: SIP/2.0/UDP 192.168.50.1:5060;branch=z9hG4bK8FD26A1EFrom: "Y K Lam" <sip:890@192.168.50.1>;tag=9AD58E64-1BCETo: <sip:2000@192.168.100.1>;tag=212D28-595Date: Thu, 22 Oct 2015 07:31:00 GMTCall-ID: AD27A3E9-77C511E5-80F5DA7E-855109A0@192.168.50.1User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Supported: 100rel,timer,resource-priority,replaces,sdp-anatTimestamp: 1445499349Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTERCSeq: 103 UPDATEContact: <sip:890@192.168.50.1:5060>Remote-Party-ID: <sip:141@192.168.50.1>;party=calling;screen=no;privacy=offContent-Length: 0
v=0o=CiscoSystemsSIP-GW-UserAgent 9239 4780 IN IP4 192.168.100.1s=SIP Callc=IN IP4 192.168.100.1t=0 0m=audio 16418 RTP/AVP 0 101c=IN IP4 192.168.100.1a=rtpmap:0 PCMU/8000a=rtpmap:101 telephone-event/8000a=fmtp:101 0-16a=ptime:20
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEPAC44F212A10F</String>
<String name="DeviceIPv4Address">192.168.54.10/24</String>
<String name="IPv4DefaultGateway">192.168.54.1</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8831</String>
<String name="NeighborIPv4Address">0.0.0.0</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborPortID"></String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">0</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN">54</String>
<String name="UnifiedCMIPAddress">192.168.100.1</String>
<String name="LocalPort">-1</String>
<String name="TimeStamp">946684897378946684853033</String>
<Enum name="ReasonForOutOfService">24</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:192.168.100.1 SIP/2.0  Cseq:156 REGISTER CallId:ac44f212-a10f000f-118f5282-18e17ade@192.168.54.10</String>
<String name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Oct 22 07:35:09.067: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad RequestVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK675da5b2From: <sip:ac44f212a10f@192.168.54.10>;tag=ac44f212a10f00027bb653b7-113a87d7To: <sip:192.168.100.1>;tag=25F73C-1C5DDate: Thu, 22 Oct 2015 07:35:09 GMTCall-ID: ac44f212-a10f0002-002af3ba-37ed3e79@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 1000 REFERContent-Length: 0Contact: <sip:192.168.100.1:5060>
Oct 22 07:35:09.079: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:09.079: auth absent
Oct 22 07:35:09.079: VOICE_REG_POOL: key(B3FC10EE0003CBED) added to nonce table
Oct 22 07:35:09.079: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:09.083: //109/417FE2418073/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK4bf4a63eFrom: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>;tag=25F748-1B66Date: Thu, 22 Oct 2015 07:35:09 GMTCall-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 101 REGISTERWWW-Authenticate: Digest realm="",nonce="B3FC10EE0003CBED",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:09.139: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:09.139: auth present
Oct 22 07:35:09.139: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:09.139: //109/417FE2418073/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK64080b13From: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>;tag=25F748-1B66Date: Thu, 22 Oct 2015 07:35:09 GMTCall-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 102 REGISTERWWW-Authenticate: Digest realm="",nonce="B3FC10EE0003CBED",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:09.155: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK69385006From: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:50 GMTCSeq: 103 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Authorization: Digest username="",realm="",uri="sip:192.168.100.1",response="746bb4c7351fd47b67e817d6a4eec1bc",nonce="B3FC10EE0003CBED",cnonce="71f57ff1",qop=auth,nc=00000002,algorithm=MD5Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:09.159: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:09.159: auth present
Oct 22 07:35:09.159: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:09.159: //109/417FE2418073/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK69385006From: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>;tag=25F748-1B66Date: Thu, 22 Oct 2015 07:35:09 GMTCall-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 103 REGISTERWWW-Authenticate: Digest realm="",nonce="B3FC10EE0003CBED",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:09.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK17e78e96From: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:51 GMTCSeq: 104 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Authorization: Digest username="",realm="",uri="sip:192.168.100.1",response="950a03b5f556573e18c275a69bfdaf04",nonce="B3FC10EE0003CBED",cnonce="1bb7042a",qop=auth,nc=00000003,algorithm=MD5Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:09.175: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:09.175: auth present
Oct 22 07:35:09.175: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:09.175: //109/417FE2418073/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK17e78e96From: <sip:2083@192.168.100.1>;tag=ac44f212a10f00033089ca18-6088dd5aTo: <sip:2083@192.168.100.1>;tag=25F748-1B66Date: Thu, 22 Oct 2015 07:35:09 GMTCall-ID: ac44f212-a10f0002-2d5e1540-3ac5194c@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 104 REGISTERWWW-Authenticate: Digest realm="",nonce="B3FC10EE0003CBED",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:13.735: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK34c974deFrom: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:55 GMTCSeq: 105 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:13.735: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:13.735: auth absent
Oct 22 07:35:13.735: VOICE_REG_POOL: key(F2005ED70003CDBF) added to nonce table
Oct 22 07:35:13.735: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:13.735: //114/444654298074/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK34c974deFrom: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>;tag=260978-BA1Date: Thu, 22 Oct 2015 07:35:13 GMTCall-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 105 REGISTERWWW-Authenticate: Digest realm="",nonce="F2005ED70003CDBF",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:13.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK2c2fecd5From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:55 GMTCSeq: 106 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Authorization: Digest username="",realm="",uri="sip:192.168.100.1",response="915e068cca80ea8e4acc49d840394779",nonce="F2005ED70003CDBF",cnonce="2c2c1193",qop=auth,nc=00000001,algorithm=MD5Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:13.747: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:13.747: auth present
Oct 22 07:35:13.747: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:13.747: //114/444654298074/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK2c2fecd5From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>;tag=260978-BA1Date: Thu, 22 Oct 2015 07:35:13 GMTCall-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 106 REGISTERWWW-Authenticate: Digest realm="",nonce="F2005ED70003CDBF",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:13.767: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK16bd4037From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:55 GMTCSeq: 107 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Authorization: Digest username="",realm="",uri="sip:192.168.100.1",response="6471f8a6db13c5c174d771edc0dca719",nonce="F2005ED70003CDBF",cnonce="752444d4",qop=auth,nc=00000002,algorithm=MD5Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:13.771: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:13.771: auth present
Oct 22 07:35:13.771: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:13.771: //114/444654298074/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK16bd4037From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>;tag=260978-BA1Date: Thu, 22 Oct 2015 07:35:13 GMTCall-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 107 REGISTERWWW-Authenticate: Digest realm="",nonce="F2005ED70003CDBF",algorithm=MD5,qop="auth"Content-Length: 0
Oct 22 07:35:13.795: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.1 SIP/2.0Via: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK6bafe6a7From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>Call-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Max-Forwards: 70Date: Sat, 01 Jan 2000 00:00:55 GMTCSeq: 108 REGISTERUser-Agent: Cisco-CP8831G/9.3.2Contact: <sip:2BD33F58-2467@192.168.54.10:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f212a10f>";+u.sip!devicename.ccm.cisco.com="SEPAC44F212A10F";+u.sip!model.ccm.cisco.com="659"Authorization: Digest username="",realm="",uri="sip:192.168.100.1",response="90fab83b523ca26e72ed28676a1187b2",nonce="F2005ED70003CDBF",cnonce="00542492",qop=auth,nc=00000003,algorithm=MD5Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1Content-Length: 0Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEPAC44F212A10F Load=sip8831.9-3-3-5.loads Last=phone-reg-rej"Expires: 3600
Oct 22 07:35:13.795: VOICE_REG_POOL: Register request for (2083) from (192.168.54.10)
Oct 22 07:35:13.795: auth present
Oct 22 07:35:13.795: VOICE_REG_POOL: No entry for (2083) found in contact table
Oct 22 07:35:13.795: //114/444654298074/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 UnauthorizedVia: SIP/2.0/UDP 192.168.54.10:5060;branch=z9hG4bK6bafe6a7From: <sip:2083@192.168.100.1>;tag=ac44f212a10f000474f6a103-5273f1dfTo: <sip:2083@192.168.100.1>;tag=260978-BA1Date: Thu, 22 Oct 2015 07:35:13 GMTCall-ID: ac44f212-a10f0003-04319d2c-42a06da4@192.168.54.10Server: Cisco-SIPGateway/IOS-15.4.3.M3CSeq: 108 REGISTERWWW-Authenticate: Digest realm="",nonce="F2005ED70003CDBF",algorithm=MD5,qop="auth"Content-Length: 0
We still see the below message:
After disabling authenticate register, did you do a "create profile". If not, please do a "create profile" on the "voice register global" and try resetting the voice register pool 1 once.
Rajan
Please rate useful posts
i already do a create profile under voice register global and have restarted the phone several times.
but the phone still not registered :(
Hi.
Under voice register global, try authenticate realm all
and create profile
After that, send again a debug
Carlo
still not register.
and here is the debug
thanks,
rocky
Hi Rocky
On pool configuration, try to remove username and password than go under voice register global and issue no create profile and create profile
Let me know
Carlo
i have remove the username and password earlier but still no change..
thanks,
Fachroky
Can you please post the debug output without username and password configuration and also the actual cme configuration?
regards
Carlo
the debug from earlier i've already remove the username and password.
here is the actual configuration
 phoneload-support
 no num-lines
 reference-pooltype 6921
 mode  cme
 max-dn 10
 max-pool 10
 load 6941 SIP69xx.9-4-1-3SR2.loads
 load 6921 SIP69xx.9-4-1-3SR2.loads
 timezone 41
 time-format 24
 date-format D/M/Y
 dialplan-pattern 1 2... extension-length 4
 tftp-path flash:
 file text
 create profile sync 046120450260533A
voice register dn  1
 number 2083
 allow watch
 type 8831
 number 1 dn 1
 presence call-list
 dtmf-relay sip-kpml sip-notify
 codec g711ulaw
thanks,
Rocky
Can you please try to apply this config?
 xml-config maxNumCalls 2
 xml-config busyTrigger 1
 num-lines 2
 description Cisco IP Phone 8831
 reference-pooltype 7937
 busy-trigger-per-button 1
 type 8831
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Carlo
i cannot reference type 7937
but i've already add the other config.. but phon still not registered
Which IOS Version and gateway mode are you using?
 Please let me know
Carlo
Carlo,
For the router i'm using ios version 15.0 and CME ver 10.5
gateway mode what do you mean ?
Rocky
