04-28-2022 04:43 AM
Dear Community members,
I just want to check if its possbile to configure IP Phone in a way that after certain rings if no one picks up, call should be auto attended and Speaker Phone should enabled?
04-28-2022 07:01 AM
No, that's not possible.
05-01-2022 04:29 PM
Hi Jaime,
Do you happen to encounter below error? and know the fix? Thanks heaps!
It is happening when I do outgoing calls and when call answered; a new window will come up and seems like call will be put on hold.
07-13-2022 08:45 AM - edited 07-13-2022 08:46 AM
@ Kaleem your requirement can be fulfilled by using the 3rd party solution MARS Auto Answer.
PFA a short writeup on the application.
The auto answer time can be configured in the solution.
On auto answer the Cisco IP Phone speaker can be turned on
for more details please write to info@parsec-tech.com
