IP PHONE BACKWARD Compatibility
ctamburello
Beginner
Beginner
a custiomer of mine has
N.01 - 7911
N.113 - 7912
N.16 - 7920
N.02 - 7936
N.08 - 7940
N.08 - 7941
N.1 - 7960
N.16 - ATA186
Running on a 4.2 calla manager.
He wants upgrade to Call manager 8.6 using MIG lic.
But he wants a kind of official Cisco Document where he can find the backward compatibility of the above mentioned IP PHONE and ATA
anyone can help me ?
CARLO
7 REPLIES 7
Hello Carlo,
Take a lokk on this link, enter at the CUCM 8.6 version to see at types of devices this version support
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Rate this if helps
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
p.mcgowan
Participant
Participant
Hi Carlo,
You can check the CUCM compatability matrix;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
this should tell you what is supported
Please rate helpful posts
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Carlo,
The existing phones will work and are supported but you will need to take precautions
as part of the process will upgrade their Firmware during the upgrade of CUCM to 8.6.
If you are running current Firmware on these phones it shouldn't be an issue
but if they are "old" then you will need to look at intermediate upgrade steps
before moving to 8.6
Let us know
Check Table 33 here.
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Hi Rob,
A question related to your comments here is that I am wondering how I can prevent the phone firmware upgrade from happening during the CUCM upgrade so it can be scheduled later?  Is that possilbe?
Brad
Hi Brad,
One thing you can do to control the phone firmware upgrade is to upgrade the phone firmware BEFORE you upgrade the CUCM.
this way you can upgrade the phones in a controlled manner and make sure there are no issues with the phone before the big upgrade of the CUCM.
I would not recommend trying to prevent the phone from upgrading during the upgrade itself but if the phone is already running the latest firmware this removes any potential issue of upgrading a large number of phones at one time.
Robert Thomas
Rising star
Rising star
Brad,
There are workarounds you can use to prevent the phones from upgrading firmware during the upgrade process. This is usually the workaround I use, it might not work for every environment.
1) Deactivate all TFTP services on the cluster before the Switch version. This will prevent the phones from upgrading while the server reboots.
2) Go into device defaults, and change the device load name to the current firmware, to prevent the phones from upgrading.
3)Activate the TFTP services on the cluster again.
At a later point you can change the load name to the new firmware, and reboot the phones.
Personally I'm against artificially preventing the phones from upgrading the firmware, but I have instances where it was necesary.
Thank you Robert and p.mcgowan those are both great ideas.  Much appreciated.
