IP phone Bluetooth report
Gidonitzhak
Im trying to get a report which phones in my Call Manager has Bluetooth enable.
there is a report that give me this information?
You can't get this from the reporting. However you can run a SQL query
against CUCM CLI and filter the query using bluetooth filter to see the
phone name and bluetooth status.
Here are good examples for SQL statements.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117726-technote-cucm-00.html
You can generate a statement for devices table for one line only to see the
name of the bluetooth column then use that column.name in next statement as
display and as filter.
**** please remember to rate useful posts
Thank you for the replay.
Can you please help me with the syntax?
Mohammed, Can you please help with the SQL query?
