10-12-2015 12:01 AM - edited 03-17-2019 04:33 AM
I have two IP phones:
Phone A, Ext: 101001
Phone B, Ext: 101002
I want to allow the 4-digit dialing. Therefore, I created a translation pattern to translate 10XX to 1010XX, in the same time I do not want the caller and called party to see the translation from 4 to 6 digits. So, I created calling party and called party transformation patterns. But there is no option on phone configuration page to add CSS for called party transformation.
Now I have the following scenario:
Phone A dial 1002 >> TP 1010XX >> Phone B shows “1001”
But on the screen of Phone A 101002,
How I can force Phone A to show 1002 only without 101002
Solved! Go to Solution.
10-12-2015 12:13 AM
Please check the service parameter "Always display the original dialed number" and change it to True, then share the result.
- Vivek
10-12-2015 12:47 AM
Another possibility is to change the service parameter "Apply Transformations On Remote Number". On a side note, with the setup that you aim to have you will need wait for interdigit timeout since you will have a variable length dial plan. That is usually something that you would want to avoid.
Sincerely
Roger
10-12-2015 12:13 AM
- Vivek
10-13-2015 09:53 PM
Thank you all,
This is how I solved the problem;
I created a calling party transformation pattern and change the calling search space for remote number transformation ONLY. in addition I changed the service parameter: Apply Transformations On Remote Number” (present under advanced section of Cisco Call Manager service).
10-13-2015 11:06 PM
Thanks for updating us. Any reason why you didn't rate my post?
10-13-2015 11:49 PM
Sorry for that
Done (+5)
10-12-2015 12:47 AM
Sincerely
Roger
10-12-2015 04:04 AM
Create TP with the pattern 10XX and prefix 10 under called party transform. On the calling party transform use the mask XXXX. This way they can redial using 4 digit pattern instead of 6 digit.
10-12-2015 05:15 AM
Like they say there are more than one way to skin a cat. The suggestions here all all valid..(+5 TO ALL)
You use Vivek's display of original dialled number or fi you want to be more specific in case you don't want this to apply to all called numbers then you can use the following combination..(Roger mentioned part of it)
1. Change the cucm service parameter "Apply Transformations On Remote Number" to True. You will need to click on advanced settings to see this..
2. Create a called party xformation of
pattern:1010XX ( assign to a partition eg Abbrev_PT)
called-party xform mask of XXXX
3. Go to the phone and under the "Number Presentation Transformation>Remote Number
Select a CSS that access to the PT your called party xformation is in and uncheck use device pool CSS
4. If you want to do this for large number of phones, you could also do it at the device pool level..
Under Phone Settings>Connected Party Settings> Connected Party Transformation CSS
assign the called part css above..
03-07-2018 11:52 PM
Just correcting step 4:
Under Device Mobility Related Information > Calling Party Transformation CSS
Select the CSS.
Connected Party Transformation CSS is applicable for inbound calls only, and won't have any effect in the above scenario.
