IP phone cant ring to other phone!!
loveman
Hello
I am installed SIP with cnf.xml and xml file and all sip files and upgrade to cisco ip phone, And worked as fine
Now i can call from zoiper to cisco ip phone and ring with listen between them,
My problem when I need to call from cisco ip phone to zoiper or other software i cant the result of debug of Asterisk voip server below:
Where the problem ?
Cisco ip phone model 7965
Thank you
6 Replies 6
Leo Laohoo
NAT
NAT in Account extension, or in Asterisk SIP settings?
Leo Laohoo
NAT should be turned off.
I am already turned off, But the problem not solved!!
Is the issue observed when you're calling internally?
Is the issue observed only when using Zoiper?
I am already using in this time only internally call and tested other software like 3xc and x-lite and the same problem!!
