IP Phone communication
dabur10376004
Beginner
Beginner
Hi, We have 4 overseas Location including HO. Lets Name is HO Location – A & rest of branch location is B, C & D B, C & D are connected with A via Site to site VPN (IPSec Tunnel) over internet as a star topology. If B wants to reach C then its connectivity is via A & same for all location. A to B --- Latency 250 ms A to C --- Latency 260 ms A to D --- Latency 275 ms B to C – Latency will be 250+260=510 ms We are planning to deploy IP Phone at B & C Location for communication. But we are suspecting Latency issue. For your information we have Microsoft Lync 2010 at A location & all B,C & D location’s users are voice/chat etc. Could you please suggest us how we should go forward? Or any topology change
8 REPLIES 8
Sreekanth Narayanan
We have seen voice calls being able to handle latencies of ~600 ms because of satellite links when the routers and phones are located on ships. So you should be able to make calls. However, registration is another matter. Where are the phones of locations B,C and D registered? If they are registered to CMEs located in locations B, C and D respectively, it should be ok, but registering phones over VPN with high latency is not possible. The keepalives will timeout and phones will get unregistered frequently.
if B,C & D have voice gateway with CME & we create additional B to C site to site VPN.
A to B & A to C site to site VPN remain same & we remove the B to C permission from Access List for reachability  between B to C via A.
doing above task, I am going correct way or suggest any other solution.
Please help us.
hi,
I am colleague of above member of this community
Although latency is 600 ms is possible for voice calling.But Here i have some concerns
1. Either we should go for deploying CME at Hub Site and all voice communication happen   through hub site of 2 spoke sites and latency will be around 600 ms
2.other point is whether we should go for individual CME for spoke sites and create vpn between spoke sites and minimize latency.
3. other point is we should deploy CME box at single spoke site and both sites IP phone register with single CME.
is it necessary to go with voice gateway solution at each site
Please suggest best and standard practices for CME and IP phone for spoke sites
communication
All suggestions will be appreciated.
regards
rajat
CME at each site to minimize the possibility of phone registration issue which may occur in hub-spoke topology and VPN tunnel between B to C will be best possible solution I can see.
You should proceed with it.
Thanks !!
Anas Abueideh
Engager
Engager
Deploy DMVPN topology for your vpn connection. in DMVPN you will create dynamically vpn tunnel between B and C, instead of passing HQ.
Anas
don't forget to rate the helpful posts
A,B,C & D locations have Cisco ASA. & we have created site to site VPN over internet between ASA to ASA. B Location's users accessing mail, sap & intranet application from A (HO ) Location. & same as C & D Location also.
you mean to say that A to B & A to C site to site VPN will remain intact(no change). as per your recommendation, need to create new DMVPN between B & C.
if yes then please share the DMVPN document.
vinod
Unfortunately, DMVPN is not supported on ASA
Anas
any help ?
How should go forward.  Please help us.
