Showing results forĀ
Search instead forĀ
Did you mean:Ā
IP Phone dual registration
Hi All,
Is it possible to register an IP phone with 2 different servers at the same time ??
Means
Line 1- Ext 1000 ---------------------- To Server 1
Line 2- Ext 2000 ---------------------- To Server 2 /CME Router
Rohit
will.alvord
Level 5
Level 5
You can register different lines to different servers with the SIP firmware but I've never tried it with CUCM/CME.  You'd have to manually configure the phone lines though or manually create/edit the config files and store them on your own tftp server to avoid them being overwritten.
