Ip Phone Firmware upgrade file NOT getting Detected on CUCM
rakshit.dua1
Ip Phone Upgrade file is NOT getting detected on CUCM install/Upgrade options...
CUCM version :- 9.1.1.20000-5
IP Phone 7941, 7942
Current Firmware on the Phone and Device Defaults :- SCCP41.9-3-1SR1-1S
Upgrading to cmterm-7941_7961-sccp.9-4-2-1.cop.sgn and cmterm-7942_7962-sccp.9-4-2-1.cop
The Upgrade files are not getting recognized as Valid Upgrades
Error "No valid upgrade options were found"
and
"Name does not match any filter pattern. "
Please see attached screenshot.
Confirmed that the MD5 value of the files uploaded on the SFTP are correct.
Please check and confirm.
10 Replies 10
Mohammed Khan
Hi Rakshit,
Try installing "ciscocm.version3-keys.cop.sgn" and then install cmterm-7942_7962-sccp.9-4-2-1.cop.sgn and see if that works
https://software.cisco.com/download/release.html?mdfid=284510097&flowid=45900&softwareid=282204704&release=COP-Files&relind=AVAILABLE&rellifecycle=&reltype=latest
HTH,
Mohammed Noor
Hi Mohammed,
Thanks a lot for the quick response,
Will try the same and update you soon.
Rakshit Dua
Hi Rakshit,
How u are uploading the firmware files?
u need to use software upgrades---> tftp file management.
you are using software installation/upgrade
please refer this
You can use the Software Upgrades options to perform the following types of installations and upgrades:
Install/Upgrade—Use this option to upgrade the application software, install Cisco Unified Communications Manager Locale Installers and dial plans, install Cisco Unity Connection locales, and upload and install device packs, phone firmware loads, and other COP files.
TFTP File Management—Use this option to upload various device files for use by the phones to the TFTP server. The TFTP server files that you can upload include custom phone rings, callback tones, and phone backgrounds.
regds,
aman
Interesting as I am getting the same issues and I am installing the phone firmware files you referenced above and your instructions state to use the install/upgrade for phone firmware loads.
Here is the screen shot and list of files.
Hi Aman,
Please find the screenshot. After uploading all four files I need to restart TFTP service right?
Hi Ramiz,
Yes, u need to restart  tftp  service on the server which  u have uploaded files.
regds,
aman
Hello Aman,
As I was reading about it I came to know we can upload firmware in two ways.
  • Install/Upgrade— if we are uploading from here then we need to upload cop.sgn file for eg: cmterm-69xx-SCCP.9-4-1-3SR3.k3.cop.sgn
  • and then tftp restart.
     if file is uploaded from here then default firmware in device defaults changes automatically.
  • TFTP File Management— if we are uploading from here we can directly select load files by unziping folder cmterm-69xx-SCCP-9-4-1-3SR3
if we uploaded files from here then default firmware in device defaults will not change automatically however new firmware files are uploaded on server.
Please validate.
HI Ramiz,
Can u share the link?
secondly, u need to install ciscocm.version3-keys.cop.sgn
http://www.cisco.com/web/software/282074289/136420/cmterm-6921_6941_6961-sccp.9-4-1-3SR3-readme.html
regds,
aman
D_Lebedev
Level 3
Level 3
I've face with same issue with our CUCM 10.5.2.
Applied keys_V3 patch,but no success.
TAC engineer also was not able to determine the reason.
What i did for success upgrade-i've created  iso image from existing cop file,uploaded it to Vmware storage and mounted it to CUCM CD-rom virtual machine.
I was able upgrade normal from local source.This issue was completely resolved in the last SU update for our CUCM.
Hope it helps.
