04-03-2019 11:58 PM
How to get report of all ip phones that are in none status in cucm, and is there a way to know when they went into none status
04-04-2019 01:08 AM
Hi There,
This value was controlled by RIS Unused Cisco CallManager Device Store Period under the Cisco RIS Data Collector service parameter. By default, it is 3 days.
RIS Unused Cisco CallManager Device Store Period:
This parameter specifies the RIS database information storage period for any unregistered or rejected device information from the Cisco CallManager service. After the time specified in this parameter expires, Cisco CallManager removes the expired entries during the next RIS database cleanup time (specified in the RIS Cleanup Time of the Day parameter)
I am not sure about the other way to find out. normally I list out all the phones from the device menu and export to excel and then filter based on the registration status column. may others have a better way to do it.
Shalid - ** Please rate helpful post **
04-04-2019 03:51 AM
In the RTMT, go to Voice/Video > Device > Device Search. Do a search for Phones that are Device Only Configured in Database. This will list all phones in the None status. In CUCM 12, you can download this list but in earlier versions it is a view-only list. There might be a way to generate such a list with a SQL query, but I don't know how to do that myself.
Maren
04-07-2019 06:12 PM
Thanks for the reply Maren,
But I cannot find the option to download this list. Please Assist
04-04-2019 08:06 AM
This is a public forum, please use internal resources if you need assistance with this kind of questions.
10-03-2022 05:31 AM - edited 10-03-2022 05:31 AM
if internal resources are not able to answer this question !!
04-07-2019 11:30 PM
