ip phone issue
if a ip phone is not getting ip address
what r the steps to be taken for troubleshooting
HARIS_HUSSAIN
If Phone not getting IP address, Probably you have to check the Vlan and IP Helper Address configuration. Also check the DHCP Server.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
luis_cordova
Hi syednoushadali492@gmail.com ,
Check this link:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7905g_7912g/5_0/sip/english/administration/guide/5_0/LowPtrb.pdf
Remember to mark the correct answers as solved, since that helps other users with similar doubts
balaji.bandi
This goes step by step diagnosis :  (any other phones working in the same switch)
1. Once you connected the Phone, do you see PoE got Power and Phone ON.
2. If Phone is ON, Do you have switch port configured right VLAN for voice(may be yourcase)
3. where is the DHCP Server ( do you vlan interface with DHCP relay / helper config where the DHCP Server Located)
4. is this only Phone having issue, or any other phones working in the same switch.?
post us the switch config, tell us your DHCP Server IP address ? what IP you expect for the IP Phone s?
BB
Leo Laohoo
Is voice VLAN enabled on the port?
Is the voice VLAN enabled on the Trunk port?
Check the voice VLAN for the correct helper address.
Check the DHCP server for the status of the subnet and lease.
HARIS_HUSSAIN
Haris
