IP Phone issues across WAN Link
Kaushik Ray
Hello
I am experiencing a strange problem for IP Phones across WAN Links.
Both end of the WAN Links are CME Routers and when a call is taking place between the two sites there is a banging background noise on the call.
I asked a test to make internal calls on each of the site like call from an IP phone to another IP Phone that is registered on the same router
and there are no issues and there is no background noise.
Can anybody advise as to what I can do to noise cancel?
Please let me know if you need any more information for this.
Many Thanks in advance,
ronpatel
Level 8
Level 8
have you Implemented QOS on WAN. What is the speed of the WAN connection.
regards
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Thanks for your reply yes there is QoS implemented on both router at the end of the WAN Link and i cannot see dropped packets when i check show policy-map int s X/X/X. The link speed is 1024Kbps
