IP-Phone keeps ringing after PSTN Call disconnect
sherif safwat
I know this is an old question , that IP-Phone keeps ringing after PSTN call disconnect .
I have followed this post https://supportforums.cisco.com/discussion/10589296/capture-pstn-parameters-fxo-disconnet
PSTN --> 2811(with B-ACD TCL) --> CUCM8.6 --> IP-Phone
the problem that after PSTN disconnect the call , IP-Phone keeps ringing also but only for 3 times . i need to cut it off and just stop ringing after the call disconnect !!
voice class custom-cptone Disconnect
 dualtone disconnect
  frequency 450 460
  cadence 255 255 255 255
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone Disconnect
 no battery-reversal
 cptone EG
 timeouts call-disconnect 1
 timeouts wait-release 3
 timing hookflash-out 50
 caller-id enable
sherif safwat
Problem solved after IOS upgrade.
Another issue appeared , the caller-id enable command seems not working after adding the supervisory commands.
The caller become unknow , any comments ?
