ip phone language , cucm10
Labanelamia
Please , I have installed cucm 10 , and i insert ip phone into by using BAT, my worry is about how can i change the language of ip phone??
thank you.
Hi there,
You're going to want the full CUCM Locale Installer. There is nice discussion on the differences in this Cisco Dockwiki;
http://docwiki.cisco.com/wiki/Cucm-phone-locale-installers
You didn't mention your exact 10.x CUCM version, but if it were 10.5.2 for example the file would be;
cm-locale-fr_FR-10.5.2.2000-1.cop.sgn
From this path on Cisco software downloads;
Unified Communications Manager/CallManager Locale Installer-10.5(2.2000-1)
9 Replies 9
Jaime Valencia
You can do that via BAT, exactly what problem are you having?
java
if this helps, please rate
You can download the locale files from CCO and upload it via the OS admin.
good morninger Avery one,
Is There a solution to make a sauvegarde of system in case of problème   ?
Devansh
Have you uploaded Locale to Call Manager after the installations. May i know what language you want to enable on the phone. If you already Uploaded Locale you need to change on phone page and end user page of the user.
I just installed cucm version 10, and I insert ip phones by using BAT, they are properly registered, now i need to change the language of ip phone to french.
when i try to create user with user locale ,i have english, United States only.
how can i upload locale ???
Hi Labanelamia,
Please find below link for how to upload the locale in call manager
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-71/113395-cucm-locale-nl-00.html
Please rate this if you find this is useful information.
Hi there,
Labanelamia
