IP Phone LSC certificate installation
Marco Biffi
Beginner
Beginner
Hi guys
We are going to deploy dot1x access with LSC certificate for our IP Phones and since we are talking about more than 400 phones  we are thinking about a bulk procedure to install them.
Is there a way to check if LSC installation has been deployed well and if LSC is installed on phones directly from the CUCM?
From the documentation I only found the way to check it from the IP phone menu
Thanks and regards
Marco
Greg Cording
Beginner
Beginner
"Generate CAPF report" Page 117 of the attached..
Hope this helps.
Greg
Greg Cording
Beginner
Beginner
Also if you are deploying 802.1X you might find this community document of great interest.
https://supportforums.cisco.com/document/73611/ip-phone-security-and-ctl-certificate-trust-list
Also consider Supplicant Link State Changes on the IP phones Switch Port, another great document attached.
Good luck with your project.
Greg
Recognize Your Peers
