IP Phone Meet Me Service
Afternoon all,
Our CUCM enovrionment consisits of mainly 7970 phones. We use the Meet Me feature that's provided with Call Manager.
We have set our 'Meet Me' parameters to 8 although the 'Suggested Value' is 4.
I actually changed this parameter to 32 and successfully managed to get 32 internal (concurrent) phones connected to a Meet Me session.
My question is this: If I ran a Meet Me session with this many phones included during a busy day, could this impact the stablilty of call processing of our Call Manager Cluster?
We have approximately 1000 phones which regsiter between 4 subscribers. Total overkill I know, but we're certainly not oversubscribed.
Please note, this is for internal calling purposes only.
Jamie
William Bell
You may want to consider running software media services on a dedicated server (or servers) in the cluster. 1,000 phones across 4 servers still doesn't tell the whole story. If you cluster is 4 nodes total, then your design may be right on par.  Depending on which server platform you are using. If you had 7835 servers, I would lean to the following node allocation:
1- Pub/TFTP
2- TFTP/software media services (MoH, software CFB, etc.)
3- Subscriber-1
4- Subscriber-2
I typically recommend separate software media processing from call processing if at all possible.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
1- Pub/TFTP
3- Subscriber-1
4- Subscriber-2
HTH.
Bill
