01-31-2020 11:49 PM
It is normally set in voice vlan 1, but not in such as vlan 10 or vlan 20
Help me
Switch
Switch#show run
Building configuration...
Current configuration : 1350 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
enable password cisco
spanning-tree mode pvst
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
interface FastEthernet0/2
channel-protocol lacp
channel-group 1 mode active
interface FastEthernet0/3
interface FastEthernet0/4
switchport voice vlan 40
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Router
v4R3#show run
Current configuration : 3869 bytes
version 15.1
hostname v4R3
ip dhcp excluded-address 192.168.1.101 192.168.1.255
ip dhcp excluded-address 192.168.1.0 192.168.1.49
ip dhcp excluded-address 172.16.3.0 172.16.3.49
ip dhcp excluded-address 172.16.3.101 172.16.3.255
ip dhcp excluded-address 172.16.4.0 172.16.4.49
ip dhcp excluded-address 172.16.4.101 172.16.4.255
ip dhcp excluded-address 172.16.5.0 172.16.5.49
ip dhcp excluded-address 172.16.5.101 172.16.5.255
ip dhcp pool DHCP-vlan30
network 172.16.3.0 255.255.255.0
default-router 172.16.3.1
option 150 ip 172.16.3.1
ip dhcp pool DHCP-vlan40
network 172.16.4.0 255.255.255.0
default-router 172.16.4.1
ip dhcp pool DHCP-vlan50
network 172.16.5.0 255.255.255.0
default-router 172.16.5.1
ip dhcp pool DHCP-vlan20
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
option 150 ip 192.168.1.1
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524FST9
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
crypto ipsec transform-set TS esp-3des esp-sha-hmac
crypto ipsec transform-set ST esp-3des esp-sha-hmac
crypto map Gmap 10 ipsec-isakmp
set peer 10.3.3.1
set transform-set TS
match address gre
crypto map Gmap 20 ipsec-isakmp
set peer 10.2.2.1
set transform-set ST
match address ipsec
interface Tunnel0
ip address 10.0.2.2 255.255.255.0
mtu 1476
tunnel source GigabitEthernet0/0
tunnel destination 10.3.3.1
interface Tunnel1
ip address 10.0.1.1 255.255.255.0
mtu 1476
tunnel destination 10.2.2.1
interface GigabitEthernet0/0
ip address 10.4.4.1 255.255.255.0
duplex auto
speed auto
crypto map Gmap
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 172.16.3.1 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 172.16.4.1 255.255.255.0
interface GigabitEthernet0/1.50
encapsulation dot1Q 50
ip address 172.16.5.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
no ip address
clock rate 2000000
shutdown
interface Serial0/3/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 10.1.1.0 255.255.255.0 10.4.4.2
ip route 10.2.2.0 255.255.255.0 10.4.4.2
ip route 10.3.3.0 255.255.255.0 10.4.4.2
ip route 218.159.40.0 255.255.255.0 10.1.1.1
ip route 192.168.1.0 255.255.255.0 10.0.2.1
ip route 192.168.2.0 255.255.255.0 10.0.2.1
ip route 192.168.0.0 255.255.255.0 10.0.1.2
ip flow-export version 9
ip access-list extended gre
permit gre host 10.4.4.1 host 10.3.3.1
ip access-list extended ipsec
permit gre host 10.4.4.1 host 10.2.2.1
no cdp run
dial-peer voice 2001 voip
destination-pattern 2001
session target ipv4:192.168.1.1
telephony-service
max-ephones 3
max-dn 3
ip source-address 172.16.3.1 port 2000
auto assign 1 to 3
ephone-dn 1
number 1001
ephone-dn 2
number 1002
ephone-dn 3
number 1003
ephone 1
device-security-mode none
mac-address 000C.85AA.0214
type 7960
button 1:1
ephone 2
mac-address 0001.64CA.D009
type 7960
button 1:2
ephone 3
mac-address 0060.47EC.9AA6
type 7960
button 1:3
line con 0
login
line aux 0
line vty 0 4
login
end
I don't know why it only works in voice vlan 1.
Solved! Go to Solution.
02-01-2020 04:42 AM
I did not find any configuration in the switch related to Vlan 20 or 30. Can you share the configuration of the port in the switch where you connected the Phone ? If you connect the phone to switch with blank config, it is going to take VLAN 1. By default all the switch interfaces are trunk interfaces with native vlan of 1 so your Phone will take native Vlan 1.
Just for recap, below is required on the switchport where phone is connected:
int gi0/x
switchport mode access
switchport access vlan xx
switchport voice vlan 20
! where xx is the Data vlan, it is required if you will connect your PC behind the Phone.
s
02-01-2020 05:24 PM
The reason why it worked.now.because previously you didn't define switchport mode access.
Also, it takes time to get rid of old ip address and get new from different vlan.
02-01-2020 04:42 AM
int gi0/x
s
02-01-2020 06:55 AM - edited 02-01-2020 07:02 AM
thank you for reply my elementary question,
i'm sorry there's no pc behind ip phone, so i configured it like below in SCSW2 at first time.
interface f 0/4
sw voice vlan 40
And as per advice, this is the setting I just tried.
int f0/4
sw mode ac
sw ac vlan 40
sw voice vlan 40
but it's same as first time. it doesnt work.
ip phone gui just show "configuring ip" even though i setting dhcp server in router v4R3
my dhcp config
ip dhcp server dhcp
default 172.16.4.1
option 150 ip 172.16.4.1
topolgy
02-01-2020 03:32 PM
Can you check with VLAN 40 is created on SW2 by checking show vlan brief, if not then create one using "vlan 40" command.
Further, can you check on the IP Phone whether it is getting IP Address or no ? try to release the old IP which it already have. Connect your Laptop also to the Phone to see whether you are getting IP from VLAN 40..
02-01-2020 05:12 PM - edited 02-01-2020 05:15 PM
Even though check vlan, didn't work..i don't know what is the problem cleary, but i retry again slowly then it work. i guess it was just my mistake or packet tracer error. Thank you.
02-01-2020 05:24 PM
