Highlighted
IP phone ON HOOK light
Does anyone know the significance of ON HOOK light, figure attached.  Have seen these on few models like 7942 etc
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Community Legend
Hi Mathew,
Hi Mathew,
The handset actually has a clear lens so the RED lamp just shines through from the light on the body of the phone for MWI or ringing.
Cheers!
Rob
6 REPLIES 6
Highlighted
Erm... that's the voicemail
Erm... that's the voicemail notification light.
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Highlighted
All, very glad to see your
All, very glad to see your replies !
So why would you need it if you have one already on top of the headsets ?
Highlighted
Hi Mathew,
Hi Mathew,
Just to add a note to the info from my friend Aaron (+5) that is also the light that flashes as part of the visual ringing notification.
Cheers!
Rob
Highlighted
MWI - Message waiting
MWI - Message waiting indicator for Voicemail
Refer section "Physical Description"
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucme/ip_phones/7942_62/4-3/english/user/guide/62_42.pdf
Mohammed Noor
Highlighted
Hi Mathew,
Hi Mathew,
Cheers!
Rob
Highlighted
Which is one of the good
Which is one of the good learning I had in the recent past, till this time I was under the impression that both of them work independently, never recognized the tiny lens system though.
You made my day Rob, Thanks
