IP Phone Registeration Best Pratctice
tahseensheir1
Hello all ,
My company have an implementation this week for 8 companies all in the same cluster on BE6M :-
No. of Phones 400 distributed on all companies and every company will use a separated extension range for example :-
1000-1099
1100-1199 ans so on
so I can't use the auto registration  method because every company must have from its own range so I can't make an auto registration from 1000-1399.
they  also have 400 DIDs as a 1 to 1 mapping so what is the best practice to configure phones and DIDs much faster ?
Deepak Rawat
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/10_0_1/CUCM_BK_CDB9A6A4_00_cucm-bulk-administration-guide-100/CUCM_BK_CDB9A6A4_00_cucm-bulk-administration-guide-100_chapter_0111.html
Deepak
Hi ,
you can apply 2 methods here.
1- Bulk configuration tool.
2- enable the auto configuration in phases. Like, enable to auto config on the server for
Range1 1000-1100 with device pool and all other things. connect all the phones
and then disable the auto registration or change the range and connect the 2nd set and next set.
Jaime Valencia
Well, that's not necessarily true, you can configure a different auto-reg range, per server.
FYI, you need to mention what version you're working with when asking here.
If 11.x, you can use self-provisioning.
java
if this helps, please rate
