03-27-2013 08:07 AM - edited 03-16-2019 04:29 PM
Hi Community,
Hope every one is well...i am having a issue with couple of new cisco 7945 CCM 6.1....iam getting ip phone registration error with db config error....i have tried everythinhg cisco and guys on google recomended apart from reeboting sub and pub as i dont feel the need for it as DB between two is synchronized and in good state...
i have tried reseting phone to default, checked Database replication of pub and sub which is in state 2 ( good), i have deleted network configs and device configs from phone, ched cucm and seeting for auto registration are fine,deleted unused assigmed DN's,Ip setting for TFTP , DNS , default gateway and ip add all looks good. i cant find phone in call manager with mac and when i try to add it says entry already exsist with same mac....in status messages i see below erros
1) DNS unknown host ------ according to cisco make sure tftp and call manger ips are resolved in DNS i have checedk DNS they are resolved and rest of pones not having any isssue only new two...
2) "MAC ADDRESS".conf.XML -------- at this points finds a file
3) file not found "MAC ADDRESS".conf.XML-------- at this point cant find file
4) no ctl found
5)file not found CTLFILE.tlv
Guys any ideas as i checked everything .....as its ccm 6.1 licenses for authorized unit is 4940 but used is 5189 i know in old call managers you can get away with adding more devices than license purchased for but the prob is its not causing prob for other devices only this,,,,,thanks
Solved! Go to Solution.
03-27-2013 09:26 AM
Hi Mohammad.
This output confirms that no device has the same mac address of the IP Phone you are trying to add.
Can post the exact error message that you receive when you try to add th Phone?
There are some bugs in 6.1 that colud fit to your case.
Carlo.
03-27-2013 08:30 AM
Do you have the same issue for multiple new 7945 devices? They were never registered to this CUCM before?
If you don't want to reboot the servers, you might want to try restarting the TFTP service.
Thijs
03-27-2013 08:38 AM
HI Thijs,
Thanks for reply yes i have issue for with both 7945, managed to put 18 succesfully on network but not these two ....prob with tftp is it will cause company wide voip outage so if gona cause outage i might as well restart servers what do you think ?
thanks
03-27-2013 08:40 AM
Hi Mohammad.
Just to be sure that another entry doesn't exist, run the following command from cucm command line:
run sql select * from device where name like '%
Carlo
03-27-2013 08:58 AM
Hi and thanks carlo i issue the command with mac of my phoen and out put i got was "column ( mac add) not found in any table in query or slv is undefined ...thanks
03-27-2013 09:02 AM
Hi Mohammad.
The correct sintax is run sql select * from device where name like '%012345678900'
Change only 012345678900 with your MAC.
Carlo
03-27-2013 09:20 AM
Hi carlo,
I issued the command on sub and pub and it gave me same output but not sure what to make of it .. below is output ta
pkid name description tkmodel tkdeviceprotocol tkprotocolside specialloadinformation fkdevicepool fkphonetemplate fkcallingsearchspace ctiid tkclass fkprocessnode defaultdtmfcapability fklocation tkproduct dialplanwizardgenid deviceleveltraceflag fkenduser allowhotelingflag tkdeviceprofile ikdevice_defaultprofile fkmediaresourcelist userholdmohaudiosourceid networkholdmohaudiosourceid unit subunit xml tkcountry tkuserlocale tkproduct_base fkcallingsearchspace_aar fkaarneighborhood fksoftkeytemplate retryvideocallasaudio routelistenabled fkcallmanagergroup tkstatus_mlppindicationstatus tkpreemption tkstatus_builtinbridge mtprequired tkqsig tkpacketcapturemode packetcaptureduration authenticationstring tkcertificatestatus upgradefinishtime fkmlppdomain transmitutf8 ignorepi tknetworklocation v150modemrelaycapable tkcertificateoperation fksecurityprofile fkdialrules fkcallingsearchspace_reroute fkcallingsearchspace_refer unattended_port tkdtmfsignaling requiredtmfreception publickey fksipprofile rfc2833disabled allowcticontrolflag datetimeinserted sshpassword sshuserid fkcallingsearchspace_restrict fkmatrix_presence fkcommonphoneconfig tkkeyauthority tksipcodec_mtppreferredorigcodec md5hash srtpallowed isstandard resettoggle tkreset versionstamp fkcommondeviceconfig huntlistforvm remotedevice tkstatus_devicemobilitymode dndtimeout tkdndoption tkringsetting_dnd isdualmode fkcallingsearchspace_cgpntransform fkenduser_mobility tkoutboundcallrollover tkphonepersonalization tkstatus_joinacrosslines tkbarge ikdevice_primaryphone tkstatus_audiblealertingidle tkstatus_audiblealertingbusy isactive tkstatus_alwaysuseprimeline tkstatus_alwaysuseprimelineforvm
03-27-2013 09:26 AM
Hi Mohammad.
Carlo.
03-27-2013 09:28 AM
admin:run sql select * from device where name like '%SEP34A84EA6D23B'
admin:
03-27-2013 09:30 AM
Hi carlo,
Error messsage iam getting is "registration rejected DB config error" this is on main screen n after this phone restarts registration process and when i press setting and click status last error is DNS unknown hos....thanks
03-27-2013 09:32 AM
Sorry Mohammad, I meant the error message that you receive from the CUCM when you try toa add that phone.
Carlo
03-27-2013 09:49 AM
Hi Carlo
Your the man...iam getting belwo error which means licenses issue but other phones were succesfuly added even though we were way above our authorized license figure...i know with older ccm you can go avove authorized license figure thats y ignored and first line told me phone is added succefully should have checked that...thanks alot for your guidance much
Add failed. [4935] Allocated licenses consumed by used and pending. Please upload additional licenses (a new license file) and try again.
03-27-2013 09:57 AM
Hi Mohammad.
Glad to Help.
Please rate helpful posts and mark discussions as answered if they satisfy your requests.
Carlo
