150
Highlighted
Beginner
IP Phone Service Reset Phones?
If I create a new IP Phone service and enable it as a Enterprise Subscription, does it reset phones?
Everyone's tags (1)
3 REPLIES 3
Highlighted
Participant
Re: IP Phone Service Reset Phones?
Esto,
I am not completely certain regarding enterprise subscriptions, but when adding a non enterprise subscription it does reset the phones that have the subscription added whether you select apply config or not. I would think it would do the same with enterprise subscriptions as well, but even if it doesn't, the subscription won't take effect until you do reset the phone, so at some point you will have to reset the phones. Maybe someone else has seen it differently, but I would do it after hours.
Jason
Highlighted
Collaborator
I would think the same as Jason. It would likely do a reset of the phones.
Please rate all useful posts
Highlighted
Beginner
Creating Enterprise Subscription did not reset the phones. However, they require a reset for the service to appear.
Thanks for the help
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
