02-14-2017 09:04 AM - edited 03-17-2019 09:31 AM
hi all,
i have configured my IP phone with PSTN calls, its ok i can send/ reception calls, but when i reception call from my mobile phone to ip phone and i hook call from mobile phone the IP phone still on ringing
where is the problem?
MM
02-15-2017 07:30 PM
your signalling is not end to end so there is no signalling to the phone to make it stop ringing when you hang up the mobile.
tell us about the components involved and send us SIP traces for instance.
cheers
02-16-2017 01:57 PM
thanks Dennis for your reply, i use FXO ports to PSTN , my configuration for fxo ports is :
voice-port 0/1/0
connection plar opx 227
caller-id enable
voice-port 0/1/1
connection plar opx 224
caller-id enable
voice-port 0/1/2
connection plar opx 327
caller-id enable
voice-port 0/1/3
connection plar opx 324
caller-id enable
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
corlist outgoing call39
destination-pattern 0T
port 0/1/0
dial-peer voice 2 pots
corlist outgoing call42
port 0/1/1
dial-peer voice 3 pots
corlist outgoing call35
port 0/1/2
dial-peer voice 4 pots
corlist outgoing call91
port 0/1/3
so what i should do to get signalling end to end?
regards,
MM
02-24-2017 01:59 AM
what should i do to resolve this problem?
