07-12-2011 01:20 PM - edited 03-16-2019 05:55 AM
Does anyone know how to specify the IP phones user-name? I am running into the same problem I have heard about before with the usernames being longer than 15 characters. Specifically, the phone is setting its username to CP-7965G-SEP and then the MAC address. If I could take off the CP-7965G- portion of it then it would be exactly 15 characters. Does anyone know where this is configured? This is needed to allow phones to authenticate with our radius server.
07-12-2011 02:24 PM
Radius ??
Phone Username ???
What system are you using ?
07-13-2011 06:28 AM
We are implementing 802.1x with digital certificates on the phones. When you do this the phones will hand off a username. The hostname of the phone will still be SEP and the MAC address, but 802.1x username that the phone submits will prepend CP-7965G-SEP instead of just SEP (that is if you are using a 7965G model phone). However, we found a way in NPS to remove the beginning portion of the username so that our AD accounts for the phones will not have 24 character usernames.
10-14-2015 03:59 PM
Hello Gayson,
Do you have the informations to remove the beginning of the portion of the username on the NPS server to have maximun 15 caracters ?
Tks a lot
