09-30-2011 01:27 AM - edited 03-16-2019 07:15 AM
Hi all,
I have some 6921 registered on a CUCM7.1 and i need to change the maximum number of call from 2 to 1 .
I see that with the current version of CUCM is not possible , can i change the maximum number of call by installing a new version of firmware ?
Thanks a lot
09-30-2011 03:46 AM
What is the value of the Busy Trigger on the line you are trying to alter.
Also if you reduce the MAX calls to 1 you will no longer be able to use the transfer function
Alex
09-30-2011 03:50 AM
I have a similar issue. Am not sure how to enable call waiting feature in 6921 IP Phones. I think cpelosin is also trying to do the same...
PC
09-30-2011 04:05 AM
Hi PC,
Are the 6921s using SCCP or SIP
Alex
09-30-2011 04:30 AM
Hi Alex,
6921 using SCCP and the busy trigger value is 1 . Also the busy trigger is not editable .
I know that if i reduce the maximum number of call to 1 , i can not use the transfer function but is a request from my customer .
Carluccio
09-30-2011 04:47 AM
Hi Campbell,
They are SCCP, CUCM 7.1.3, Phone firmware: SCCP69xx.8-5-3-0
09-30-2011 05:47 AM
I have tried searching for relevant bugs re Max No of Calls & Busy Triggers for both CUCM Ver 7.1 or 6921s.
I can not find any relevance.
I suggest you raise a TAC case.
Alex
09-30-2011 06:02 AM
01-18-2013 01:03 AM
Were you able to find a solution? thanks
01-18-2013 01:30 AM
Hello Dmitry,
TAC recommended a patch installation. But we didnt do it, since started upgrading to 8.6. In 8.6 it works fine..
Thank You
PC
01-18-2013 06:07 AM
In 8.something (Maybe 8.5) CUCM/69xx phones were enhanced to allow you to configure busy trigger. When the 69xx first came out, they were hard coded to only have busy trigger values of 2/1
GTG
01-18-2013 03:22 PM
Just a note for Gordon: In 8.6 not 8.5 phones were anhaced to allow you to configure bussy trigger
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
01-18-2013 04:48 PM
Yes in 8.6 you can set the max calls per line and busy trigger to values much higher than before.
However the phone itself will not allow you to interact with those additional line appearances.. For example if you have a 69xx phone and you set the line to 4 calls and 2 calls trigger busy, you will be able to transfer / conference, and receive a 2nd call.
Only problem is you won't have an answer / divert softkey when the 2nd call comes in, and you won't be able to navigate between calls to select the call you wish to resume.
So thanks Cisco, it seems you have only half way resolved this issue.
Either allow us to assign the same DN to multiple button on a phone, or allow us to navigate within the lines of a single button. Otherwise we are forced to create phantom partitions and complicated forwarding rules.
