06-03-2013 03:08 AM - edited 03-16-2019 05:39 PM
Hi All,
We changed our POE switch to now use a Cisco Catalys CISCO 2960-S (48 Ethernet 10/100 PoE ports). Since then we noticed that we had to replace more often Nortel Avaya 1140E IP Phone which were all dead after a while.
Avaya 1140E IP Phone are POE Class 3 compatible with 6.0 W in normal operation (10.5 W maximum usage).
Does anybody experienced anything similar ?
I suspect a power surge from the Cisco's POE switch. However I am not sure where to start with this issue.
Thanks & Regards
Nick
06-03-2013 03:44 AM
I've never seen this happen before.
If your phones can go up to 10.5w, have you set the ports to go no more than, say 11.0w?
06-03-2013 04:11 AM
you can see real power consumption on each port
sh power inline
06-03-2013 04:34 AM
Hi ,
You can run the commands to diagnose the problem
a. debug ilpower powermanagement
b. debug ilpower port on which Avaya Phone is connected
regds,
aman
06-03-2013 05:39 AM
Hi all,
Thank you for your feedback.
Finally it is possible that our telephone sets are simply getting old after 3-4 years. Therefore changing the switch is a pure coincidence to see the phones burning out.
I found two interresting article about Avaya 1140E IP phone dying after a few years:
http://forums.networkinfrastructure.info/nortel-ip-telephony/1120e-1140e-models-failing/
http://www.bluemunkey.com/?p=47
Nick
06-03-2013 05:52 AM
Hi Nicolas,
You can approach Avaya if boxes are covered under warranty or AMC since some sort of workaround/repair is also mentioned in second link provided.
regds,
aman
