05-24-2012 11:43 AM - edited 03-16-2019 11:20 AM
I'm running CME 4.1 on a 2901 and have a Dell laptop running RedHat 5.7. I don't believe that Cisco has released a version of the IP Softphone software that is comptaible with Linux. My question is there a release that is compatible with Linux or another vendor solution that is compatible with CME and Linux?
Solved! Go to Solution.
05-24-2012 12:06 PM
Hi Shane,
You can use x-lite (softphone) with linux (search engine = x-lite with linux)
Here's a cool blog on the "how-to with CME" from great netpro Bill Bell;
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
05-24-2012 12:06 PM
Hi Shane,
Cheers!
Rob
05-24-2012 01:03 PM
Rob,
Thank you for your suggestion. The blog link is a real plus.
Best,
Shane
P.S. If there are additional products that anyone is aware of it would be much appreaciated.
