Hi Peter,
Kindly provide me the complete Call Flow for this type of calls. E.g.: FAX Machine -- 2911 Voice GATEWAY -- SIP -- CUCM -- SIP -- Gateway 2 -- PRI.
Once the call flow is provided please also provide the show runn of the gateways involved so that I can check the FAX configurations.
Lastly please make sure no MTP, transcoder or any kind of media resource involved within the FAX call as that could be the cause for failure.
Also confirm if the audio call is working on the same numbers.
Thanks and Regards
Akshay Sachdeva
(aksachde@cisco.com)
