01-09-2009 12:51 PM - edited 03-15-2019 03:26 PM
Hi all,
I am new with IPCC Express 5.0 (CRS 5.0).
I need to know with which Database type CRS 5.0 is compatiblie with?
Is PostgreSQL supported by IPCCX 5.0 ? if not whic other DBs that can be supported?
Please i need urgent help
Thanks in advance.
Solved! Go to Solution.
01-09-2009 07:05 PM
It depends on which DB you're asking for.
For internal DB (for configuration, historical data, etc.), it supports MSDE 2000 and MS SQL 2000+SP4.
For external DB, it supports Oracle 10g, Sybase Adaptive Server 12, IBM DB2 8.2, MSSQL 2000/2005. Check compatibility matrix:
01-09-2009 07:05 PM
01-10-2009 02:37 AM
Thanks a lot, i was looking for external DB compatibility. This solved my issue.
Thanks again.
Best Regards.
