07-07-2012 07:40 AM - edited 03-16-2019 12:04 PM
Hi All,
I have an issue with our iPhone jabber clients with CME. The issue was first brought to my attention as users couldn't log into their CUE voicemail. They would dial the mailbox extension, get the prompt to enter their mailbox number and press #, which they would do. I tested further, and noticed that all DTMF tones from the iPhone client is unrecognized. CUE doesn't "hear" the mailbox number, and I tried various other businesses, which don't "hear" the DTMF tones (press 1 for sales, pressed 1, doesn't work). This works fine with our physical phones (7970,60,40s, etc.) so it looks like an iPhone client issue.
Any ideas?
David
07-17-2012 08:50 PM
Hi David
I am having the same issue with my Jabber mobile clients with a CUCM and 3rd Party Voicemail system.
I need to troubleshoot the logs to see the DTMF codes but were you able to resolve it?
Cheers
Andy
07-18-2012 07:12 AM
Hi Andy,
Still not working on my end. If I get somewhere I'll update the thread, and please do the same.
Anyone have any ideas on this?
Best,
David
07-18-2012 08:05 AM
David,
May be this is related.
Can you ensure that you bind an interface for SIP to ensure continuity for media & signalling
something like
voice service voip
sip
bind all source-interface gigabitEthernet 0/0
Alex.
Please rate useful posts.
07-18-2012 08:14 AM
Hi Alex,
Thanks for the reply. Unfortunately, still not recognizing dtmf key presses. I've updated my original post to include my relevant config.
Best,
David
07-18-2012 08:57 AM
David,
Lets try and see if we can capture whats going on when digits are entered.
Send the output of the ff: debug
debug voip rtp named-event
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-20-2012 06:43 AM
Hi Aokanlawon,
How are you?
The debug is here. Dialed # is 777 cue VM, then tried to dial mailbox: 101#
Thank you,
David
07-20-2012 06:59 AM
David from the trace, the jabber client are using pt=106. (payload type =106)
Jul 20 13:39:23.935: s=VoIP d=DSP payload 0x6A ssrc 0x3B77C678 sequence 0x7BFE timestamp 0xC191D6B3
Jul 20 13:39:23.935: <<
Jul 20 13:39:23.935: s=DSP d=VoIP payload 0x6A ssrc 0x3B77C678 sequence 0x7BFE timestamp 0xC191D6B3
Jul 20 13:39:23.935: Pt:106 Evt:1 Pkt:0A 00 A0
Jul 20 13:39:23.967: s=VoIP d=DSP payload 0x6A ssrc 0x3B77C678 sequence 0x7BFF timestamp 0xC191D6B3
Jul 20 13:39:23.967: <<
Jul 20 13:39:23.967: s=DSP d=VoIP payload 0x6A ssrc 0x3B77C678 sequence 0x7BFF timestamp 0xC191D6B3
Jul 20 13:39:23.967: Pt:106 Evt:1 Pkt:0A 01 40
Jul 20 13:39:23.983: s=VoIP d=DSP payload 0x6A ssrc 0x3B77C678 sequence 0x7C00 timestamp 0xC191D6B3
We can see the events 111 on the router as the keys are pressed.
Can you send me a debug ccsip messages when you make a call to voicemail please.
07-20-2012 08:20 AM
Hi Aokanlawon,
Ccsip message debug is here.
I'm just using cue vm as an example, but it doens't work with any external AA, like if you call the airlines, they don't register the key presses either.
David
07-20-2012 08:29 AM
David I wouldnt expect it to work with any external AA. Because I belive on your outbound dial-peer (sip trunk) You have configured dtmf-relay rtp-nte. Now this uses pt 101. But your phone is using pt 106 for dtmf. You will need to find a way to change the payload type used on the jabber client to match whats on your configuration.
07-18-2012 07:05 PM
guys, I have resolved my DTMF issue from the iPhone to my 3rp Party VM system.
On the device page I selected the 'Require DTMF Reception' and now it recognizes the DTMF digits.
Not sure why but without it the NTE packets are sent multiple times.
Jabber for iPad and Jabber for Windows are okay.
hth
Andy
