04-17-2013 06:04 AM - edited 03-16-2019 04:51 PM
We have Cisco CUCM 8.5 and 2821 router ver 15.x. H323 pri gateway for CUCM.
HW CONF and TXCODE is configured on VG router.
Problem I am facing is,
PSTN--------->VG------------------->CUCM------------------->WAN LINK---------->(Phone C)
(Phone A)(Phone B)
Main Office I have Cisco VG, CUCM and Phone A,Phone B at Branch I have Phone C
G711 codec used in Main Office and G729 codec is used across wan link.
HW MRGL is PhoneA, Phone B, Phone C
Incoming call to Phone A cant be trasfered to Phone C
VG, PhoneA,B are in MainOfiice Device Pool, Phone C is in WAN Device Pool.
All the phones are added to Hardware MRGL.
Note:
Hardware MRGL is PhoneA,PhoneB and PhoneC
HW CONF and TXCODE are registered with CUCM, MRGL has these conf, txcode as well as MTP also added.
I can Call PhoneA and PhoneC and establish conference to PhoneB
I was not able to find out the reason, when I get incoming call from PSTN to MainOffice IP Phone, I cant transfer the call to Branch office phone.
However all the Phones(A,B,C) are added to Hardware MRGL.
VG TXCODE, CONF config
sccp local FastEthernet0/0
sccp ccm 172.16.108.21 identifier 2 priority 2 version 7.1
sccp ccm 172.16.116.21 identifier 1 priority 1 version 7.1
sccp
sccp ccm group 2
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register VG1-CONF
sccp ccm group 1
associate profile 1 register VG1-XCODE
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 12
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
Pls. suggest
Solved! Go to Solution.
04-29-2013 08:20 AM
You need to check the configuration on your dial-peers. do you have have voice class codec configured on your inbound dial-peer? What type of phone is phone C is it a sip phone?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-30-2013 12:00 AM
Phone "C" is SCCP phone.
Problem is : Call to Branch Phone "C" calls from PSTN is consuming HW Transcoder.
Codec uses is g729
here is the dial-peer config on VG
Dial-peer config
dial-peer voice 4545 voip
tone ringback alert-no-PI
translation-profile outgoing addinPrefix
destination-pattern 8...
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:172.16.x.x
dtmf-relay h245-alphanumeric
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
rgds
Rajesh
04-30-2013 12:20 AM
Please add this codec to your voice class..g729r8.Recnfigure as follows and test again.
voice class codec 1
codec preference 2 g729r8
codec preference 3 g729br8
05-01-2013 12:35 AM
Hi Aokanlawon
Voice Gateway codec configuration changed is as below.
I have changed the MRGL for all the phone as below. Under MRGL - First is MTP MRG, second is Software CFB amd last is HW CFB and TXCD.
But still, all the transcoder is being used in VG. I am not able to figureout the issues.
Pls. let me know any logs required ?
voice class codec 1
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
Pls. suggest
Rgds
Rajesh
05-01-2013 12:39 AM
OK..
DO a test call snd enable the ff debugs
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
also send CUCM SDI Traces..
Include calling and called number...Please check that the calling and called numbers are in the SDI traces before sending it
05-02-2013 10:24 PM
Dear aokanlawon
Rajesh Kumar
05-03-2013 12:23 AM
Hi Rajesh,
I went over the traces. Now this was not a straight forward conference call between three parties. For one, the PSTN caller had already called in and was talking to someone else. As a recommendation, for analyzing purposes, try and keep the problematic call as simple as possible.
Coming back to the issue, the conference bridge being allocated is :
CFB_2
The hardware conference bridge is not allocated. The CUCM based software conference bridge is not able to use G729, thus you call drops. Now there are two possible colutions to this problem:
> Put the Hardware Conference resource ina different MRG and put that MRG on the Top of the MRGL for the Phone A ( Extension 8641 ). That way force the CUCM to use that conference resource.
> In case you want to use the CFB_2 or CFB_1, i.e. CUCM based conference resources, then you need to use a Xcoder between the conference bridge and the remote site phone.
A Xcoder is always invoked by the side which has the higher bit rate codec, thus the conference bridge will try and look for a xcoder in its MRGL. That means it will look for the resource in the MRGL assigned to the Device Pool which it is a member of. This is not a recommended method of deployment.
Thus to sum up, you had three MRGs in that MRGL assigned to Phone A : mrg-test1:mrg-test2:mrg-test3
The CUCM based software conference Bridge are the members of Group 1, hence get allocated :
MRM::getUcbDeviceGivenMrgl DeviceName=CFB_2 DeviceType=50 Group=1
MRM::getUcbDeviceGivenMrgl DeviceName=CFB_1 DeviceType=50 Group=1
MRM::getUcbDeviceGivenMrgl DeviceName=VG1-CONF DeviceType=52 Group=2
MRM::getUcbDeviceGivenMrgl DeviceName=VG2-CONF DeviceType=52 Group=2
Jagpreet
05-03-2013 12:37 AM
Hi Jagpreet
Thanks a lot. What I understood from ur reponse is, if I move hardware resouce on top of list under MRGL, then problem will be resolved ?
mgr-test1 is MRG MTP, meg-test2 is SW conference, mrg-test3 is hardware txcd and conf.
All the phones use this MRGL.
Also I want to clarify, when I configure device pool with different MRGL and phone device with different MRGL, then phone specific MRGL will override device pool, correct ?
Pls. suggest, if I put hardware mrg with txcd and conf before software mrg, problem will be resolved ?
rgds
Rajesh Kumar
05-03-2013 01:59 AM
Rajesh, just as Jagpreet mentioned this is not a simple straight forward conference...First of all external party called extension 8641..You didnt mention this...Then 8641 called 8711..
Yes CFB_2 was allocated for the conferrence...
The three parties dialled into the conference..
+++extension 8641 dialled into the conference..this phone is set to use G711 between it and the CFB_2 device+++
21:59:27.909 |Digit analysis: analysis results|1,100,17,110528.47^172.16.196.21^Port 48100
21:59:27.909 ||PretransformCallingPartyNumber=8641
|DialingPartition=
|DialingPattern=b00104310008
21:59:27.909 |RegionsServer::MatchCapabilities -- kbps=64, capACount=11, capBCount=3|*^*^*
21:59:27.909 |UnicastBridgeControl::CcSetupReq reassign bridge entry PL=5, PLDmn=0|1,100,17,110528.47^172.16.196.21^Port 48100
++++++The external number also dialled into the conference and the region used is also G711+++
21:59:27.911 ||PretransformCallingPartyNumber=90501657237
|DialingPartition=
21:59:27.913 |MediaManager(326521)::mapVideoCallToMMCallType, policy=0, hasRSVP=0, videoCap=0,dataCap=0, mmCall=1, V region(e2e=384, 1)|21:59:27.912 |
UnicastBridgeControl::allocateStream - Device Name=CFB_2, StreamAvailable=46 StreamUsed=2 MaxStreams=48|1,100,17,110528.47^172.16.196.21^Port 48100
21:59:27.912 |RegionsServer::MatchCapabilities -- kbps=64, capACount=6, capBCount=3|*^*^*
+++Then extension 8711 also dialled into the conference, but its set to use G711 to the CFB_2+++
21:59:27.914 ||PretransformCallingPartyNumber=8711
|DialingPartition=
|FullyQualifiedCalledPartyNumber=b00104310008
21:59:27.915 |UnicastBridgeControl::allocateStream - Device Name=CFB_2, StreamAvailable=45 StreamUsed=3 MaxStreams=48|1,100,17,110528.47^172.16.196.21^Port 48100
21:59:27.915 |RegionsServer::MatchCapabilities -- kbps=8, capACount=12, capBCount=3|*^*^*
CUCM CFB cant do G711 and G729.
Another key thing is that extension 8641 is been recorded..So we see another sip leg into the call
INVITE sip:22222@172.16.108.166:5060 SIP/2.0
Via: SIP/2.0/TCP 172.16.196.21:5060;branch=z9hG4bK42359641a02f
From: "Auth" <8641>;tag=202353~f8914201-968b-48be-a7da-09d79f7c3acb-319360888641>
To: <22222>22222>
SIP/2.0 200 OK
Via: SIP/2.0/TCP 172.16.196.21:5060;branch=z9hG4bK42359641a02f;rport=5060
From: "Auth" <8641>x-farendaddr=b00104310008;isfocus>;tag=202353~f8914201-968b-48be-a7da-09d79f7c3acb-31936088
To: <22222>;tag=294717
Call-ID: 6566f00-1821a97f-157f8-15c410ac@172.16.196.21
CSeq: 101 INVITE
Contact: "WitnessRecorder" <22222>
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, UPDATE
Min-SE: 1800
Session-Expires: 1800;refresher=uac
Supported: timer
Require: timer
Content-Type: application/sdp
Content-Length: 30822222>22222>8641>
v=0
o=4855 137607 0 IN IP4 172.16.108.166
s=WitnessRecord
c=IN IP4 172.16.108.166
You can either remove the CFB_2 from your MRG, so that you only have Hardware CFB in the MRG or put Hardware CFB at the top of the MRGL in a seperate MRG.
05-03-2013 02:22 AM
Dear aokanlawon
Thanks a lot.
Yes, recording is ebabled for extn 8641. I understand CUCM sw CFB cant do g711 and g729.
Since cucm sw CFB is required for same office conference call. What I will do is, I will put Hardware CFB and Hardware TXCD at the top of MRGL.
I hope this will resolve the issue.
Let you know once I tested with it.
Rgds
Rajesh Kumar.
05-03-2013 02:18 AM
Hi Rajesh,
Yes, if you move the Test MRG 3 to the top of the MRGL, the problem should be solved. Yes the Device MRGL takes precedence over the Device Pool MRGL.
Thus make the change in the MRGL and make sure that it is applied to the phone which will initiate the conference call and then Save and Apply Config on the IP Phone. Reset it just to be sure. Try another test call, make sure that this phone initiates the conference.
You can run "show sccp connections" on the router which has the IOS based conference bridge on it to make sure that the conference bridge is being actively used.
Jagpreet
05-09-2013 01:39 AM
Great info. Thanks Jagpreet. 5+
Vinay Sharma
Commuity Manager
