IPT <getDeviceCaps> usage tag Confusion
Asif Khan
Beginner
Beginner
Hi All!
I am currently developing an application where the model of the phone must be determined.
I am using the provided Cisco IPT-SDK for the application development, where XML tags are used.
CUCM=8.5
Phones: 7940,7941,7970
Webserver for IPPhone services: IIS 6.0 on windows 2003
Well in the cisco document, the <getDeviceCaps> is mentioned to query a device for its type,model and other details.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/8_0_1/DeviceQueryViaCTI.html
My question is, How do I integrate this into my code? It says it can be used with post, but I am puzzled all over. cant figure it out. how do  get this tag to work?
Waiting for your inputs!
Thanks!
Stephen Welsh
Enthusiast
Enthusiast
I don't believe it's possible to combine line details from multiple sources to a single device profile other than implimenting something programatically as custom applicaiton, not a simple task
I would recomend you create multiple 'per department' device profiles for each user, but impliment a way to make it simple/consistent for users to login with the correct profile.
The easyist way would be to include a short department code in the Device Profile name i.e.
JBLOGGS_PED - Peditration
JBLOGGS_PRA - Practice
Becuase the user has multiple profiles they will be given the choice to choose the relevant one, for example:
Note the best solution as it's open to user error
Alternatively if you are happy to write a simple web application you could leverage the following information:
The Extension Mobility URL the phone uses to login is actually quite basic and includes the following query string parameters:
nameDevice NameuseridUsers login IDseqUsers PIN numberdevProfThe Device Profile to login (if there is more than one)
name
userid
seq
devProf
http://ucm91:8080/emapp/EMAppServlet?device=#DEVICENAME#&userid=jbloggs&seq=12345&devProf=
JBLOGGS_PED
Thanks for your input. So basically, this means if we set the header "x-CiscoIPPhoneModelName" in the Response.Addheader() asp object, the phone should return the model? right?
and when the phone gives the output, how do we collect it in our asp variable to display? I know how to dsiplay a variable on an IPT screen, but dont know how to collect response from this header then...!
I am also giving it a try on my server.
Not quite, other way round, when the phone request a page from your applicaiton you can fo this:
Request.Headers("x-CiscoIPPhoneModelName")
To get the model of the requesting phone, assuming you the phone is sending you the request in the first place.
Stephen Welsh
CTO
http://www.unifiedfx.com
hmm..Thats a very important point... I am going to try that on my server tomorow and get back...
Thanks for you Help!
