10-22-2010 04:16 AM - edited 03-16-2019 01:29 AM
The phone currently has only character 13 positions
to display data from the "Line Text Label".
Using CUCM v7.0.2
Is it possible to remove the cisco logo to add space for extra characters?
Or
beneath the displayed text is another space,
is there another field that maps to this space?
tks,
Pieter
10-22-2010 06:13 AM
Neither of what you're asking is possible
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-22-2010 06:42 AM
That's unfortunate. Having the Cisco logo on there is really obnoxious and limiting.
Is there an appropriate place to submit such a request as a future firmware enhancement?
10-22-2010 06:45 AM
Get in touch with your AM or your local Cisco SE and tell them you'd like to submit a PER.
java
10-22-2010 07:17 AM
thanks for the response
offcourse this was not what i wanted to hear, but it is a clear statement.
10-22-2010 10:15 AM
It is actually possible to replace the Cisco logo (which personaIly I do not find in the least obnoxious ) with another logo.
The steps to do this can be found at the link below
As Java stated it is not possible to remove the logo and use the space to display any other type of data.
Please rate helpful posts
10-22-2010 11:19 AM
Indeed, but it's not the content that's irritating, it's the space it consumes that could be used for something more descriptive.
Anyway, thanks for the responses!
10-25-2010 12:31 AM
Hi James,
thanks for thinking with me,
I knew about the possibility to change the logo.
Even with an ingenious construction to dynamically change this logo with some info (like you can change the background on other models ) this is not what I was looking for.
Pieter
