Is it possible disable directory key or remove specific directories?
DougVogel
I am running CUCM v7
Is it possible to stop the directory key from functioning (i.e. disable it) or is it possible to remove specific directories?  We have common phones and certain sites would like the directories disabled in common areas.
Thank you
Scott Brien
Doug,
this can be acheived by the following:
Log into your CUCM admin page browse to device > Device Settings > Phone services in here you will see all your directories.
You can enable and disable these from here, please note this will disable directories accross sites.
Alternatively i beleive you could put bogus information in the directory feild in the phone configuration page for phones which do not want to have directories shown.
Scott
