Is it possible to change the 7 available ringtones for individual lines on a 79xx phone?
ghflynn
Hi all,
I was wondering if it's possible to modify/change and/or add to the seven available ringtones that can be set on a per line basis on the 79XX phones?  I'm not seeing how that could be dones since I don't see them in the Ringlist.xml file.  This file only contains the ringtones that can be set as the phones default ring.  Thanks in advance.
Glen
Rob Huffman
Hi Glen,
You will need to look for the distinctiveringlist.xml as these are the Rings
used for the secondary lines on an IP Phone
For older Windows CUCM versions but can the principle is still the same;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/7_0/english/administration/guide/7961cus.html#wp1030668
Cheers!
Rob
Rob Huffman
Hi Glen,
Cheers!
Rob
Thanks......That's what I needed.
Glen
