Is it possible to do inter-chassis CUBE redundancy on ASR 1004?
jclemons978
Hi all,
   I am trying to do CUBE HA using HSRP on the ASR 1004.  I found the configuration example on Document ID: 112095.  I was going through the steps however and got to Step 2: Enable HSRP where the redundancy scheme is set to inter-device.  I do not have this option in the config.  I figured I am missing a license, so I contacted my reseller and he contacted Cisco support who said redundancy is not available on the ASR 1004, only the ASR 1006.  I think this must be incorrect.  (Even though the document does say it is for the ISR G2.)  Does anyone have any other ideas on enabling failover on the ASR1004?
Thanks.
Jonathan Schulenberg
I don't have a document but I do have some fancy slides to share:
Please remember to rate helpful responses and identify helpful or correct answers.
Hello Jonathan,
How may I get a copy of that Cico Live presentation, you refered to above?  I am currently in the process of designing Box to Box redundancy for the 1002 X in my Organization
Richard
PS.  See you have gotten even wiser (more grays) since UC 8 Beta in San Jose
Hi Dear,
Do you have sample configuratiojn for box to box ASR1K using with HSRP ?
can you please share with me sample config ?
thanks
