Is it possible to Import a list of Route Patterns in UCM 6.1.2
jean.ledoux
Is it possible to import a list of route patterns in call manager 6.1.2 ?
And how do you do it?
Best regards
Jean
3 Accepted Solutions
AFAIK it's not possible, only export to file is an option.
There are some mandatory fields for route patterns and this is why there is no import option.
BAT does not provide this kind of capabilities, you can only export
java
if this helps, please rate
java
UCM 7.X provides more exporting and importing functionality then previous releases. One is the ability to export and import dialplans.
No go for 6.1.2
java
java
No go for 6.1.2
