10-23-2014 07:54 AM - edited 03-18-2019 11:25 AM
We have a 7841 set up as lobby phone. Now we want to allow visitors to search corporate director for extensions only. I can create another directory server to contain just the extensions. But i am not quite sure if we can specify different URL for this phone only, other phones can access the URL with full information.
Please advise,
thank you
Solved! Go to Solution.
10-23-2014 08:25 AM
You could try creating two different ephone templates - one for normal phones and one for lobby phones:
I haven't tested this, but I see no reason why it shouldn't work. Try it out and let us know.
Cheers
Sean
10-23-2014 08:00 AM
You need to mention what call control you use, and version.
10-23-2014 08:05 AM
CME 10.0.
Thanks Java
10-23-2014 08:25 AM
Cheers
Sean
10-23-2014 08:55 AM
the 7841 is running sip so i put following configs.
voice register global
mode cme
url directory http://192.9.200.83/dir/main.xml
voice register template 2
url AppDialRule http://192.9.200.83/dir/main2.xml
url DirLookupRule http://192.9.200.83/dir/main2.xml
voice register pool 2
busy-trigger-per-button 1
id mac 00E1.6DBA.8EC9
type 7841
number 1 dn 2
template 2
presence call-list
dtmf-relay rtp-nte
username 4007 password 4007
description Lobby Floor
codec g711ulaw
no vad
the phone still use the directory pointed out in global mode, not the one in template 2. Any idea?
Thank you Sean
10-23-2014 08:57 AM
Did you try resetting the phone?
10-23-2014 09:17 AM
yes i did reset the phone several times. also did no create profile and create profile in voice register global.
it seems that the phone only receive the url directory defined in global service mode, not the one in the template.
thank you for your time.
10-23-2014 10:56 AM
As this 7841 is a kind of new phone, we have following configs for the pool-type. I don't know if this is really matter.
voice register pool-type 7841
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
phoneload-support
telnet-support
num-lines 4
description Cisco IP Phone 7841
reference-pooltype 6941
10-25-2014 07:07 AM
turn off the command url directory in voice register global and everything works fine.
thank you
10-27-2014 04:21 AM
Great news! I was going to set up a lab today but this saves me the trouble :)
