09-25-2012 11:59 PM - edited 03-16-2019 01:23 PM
For the below show version, is the IOS version 12.4(24)T4 or it is 12.4(13r)T11?
I am asking this because I have UCCE solution (ICM version 8, CVP version 8 and CUCM version 8.6) and it is required for the voice gateway that is also voice browser to have the version 12.4(24) T2 or later, so I need to be sure that I am applying the proper one (that is why I need to be sure if it is 12.4(24)T4 or 12.4(13r)T11)?
VoiceRTR-KWT-1#show version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 05:39 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
VoiceRTR-KWT-1 uptime is 9 weeks, 3 days, 15 hours, 52 minutes
System restarted at 22:52:11 kwt Thu Jul 19 2012
System image file is "flash:c2800nm-ipvoicek9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2821 (revision 53.51) with 1032192K/16384K bytes of memory.
Processor board ID FHK1331F202
2 Gigabit Ethernet interfaces
62 Serial interfaces
2 Channelized/Clear E1/PRI ports
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
253008K bytes of ATA CompactFlash (Read/Write)
Bilal
Solved! Go to Solution.
09-26-2012 12:02 AM
Read in bold:
09-26-2012 12:02 AM
Read in bold:
