Is my call flow scenario possible?
Ryan Ponikvar
Hi all!
I just purchased a cisco phone system from a reseller who preprograms it and ships it to customers to setup. I ran into an issue when I was going through their initial call flow setup form where I said I wanted all 10 phones to ring when our main line was called and then have the ability to transfer that call to a group of phones for someone to pick up. They said they weren't sure how to set it up but decided to send me the system anyway. So my question is, is this type of call flow possible?
A little more detail...
We have: 10 - cisco 7961g phones, 1 - 2921 router (which I believe is running Call Manager 8.4 or .5), 1 - SG 200 poe switch.
I have everything setup so that the phones are all on vlans and all the usual stuff.
Our business has 2 main departments, Dept1, and Dept2, 5 phones in each dept. If someone calls our main line, I want all 10 phones to ring, and if someone in Dept1 picks up but the customer asks for Dept2, I want the ability to transfer to Dept2 and ring all of the phones over there until someone takes the call. Our phones are not tied to employees because its a warehouse setting which is why all phones in Dept2 would need to ring if transferred.
So, is this possible? Thanks in advance!
Brandon Buffin
Yes, you can use parallel hunt groups. See the following link and example.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmecover.html#99042
voice hunt-group 1 parallel
pilot 1000
list 1001, 1002, 1003, 1004, 1005, 1006, 1007, 1008, 1009, 1010
final 1111
timeout 20
voice hunt-group 2 parallel
pilot 2000
list 1001, 1002, 1003, 1004. 1005
final 2222
timeout 20
voice hunt-group 3 parallel
pilot 3000
list 1006, 1007, 1008, 1009, 1010
final 3333
timeout 20
Brandon
Brandon Buffin
pilot 1000
final 1111
timeout 20
pilot 2000
final 2222
timeout 20
pilot 3000
final 3333
timeout 20
Brandon
Awesome Brandon. Exactly what I was looking for! Do you know how the line appearances would look in this situation?
Line appearances look the same - 1001, 1002, etc. When you dial 1000 all of the phones in the hunt group will ring simultaneously.
Brandon
