As long as it is UCM 5 or higher, you can just type the IP address with nothing else and get there. Just put in 192.168.1.1 hit enter and you should get there. Version 4 made you use the https as well as the ccmadmin, but 5 and higher, just the IP will work.
Please rate if this helped.
