Is there a way to list the configuration in call manager
marc.reiter
Is there a way to list out the configuration of call manager like you would with a cisco switch or router? (sho run)
I'd like to do things like search for what forwards to a certain extension, and that would be a lot easier if I could see the entire configuration at once.
- Marc
lusandi
I would like to apologize but this is not possible, even the backup of the CUCM system it is about 12GB of space.
Luis Sandi
Jaime Valencia
The closest thing would be to look at the numplan table in the DB.
Or use BAT to export the configuration from the phones.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
MARTIN STREULE
Check out "Variphy Insight".
You can make reports (csv, pdf, ..), snapshots, compare snapshots ("what has changed since last time") and there's a  lot more.
http://www.variphy.com
You can request an eval copy there.
Hope that helps.
Cheers,
Martin
