Is there a way to run a report to show the DN and the phone description
hankej
I am look to run a report on Extensions 1000-1999 and I would like to have the phone description of each extension.
Is there a way to do this is CUCM 8.6.2?
Jaime Valencia
Use BAT to get that information
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thank you Jaime,
I will look at the BAT.  I just briefly looked and see the Find and list phones, but it didn't give me the extension number in the view.  I will look further as it looks promising.
