12-02-2010 07:53 AM - edited 03-16-2019 02:14 AM
My customer has many iphone 4 and he plans to upgrade his cm.
His main question is: Do they plan to implement factime application ?
Any help will be appreciated
Philippe
Solved! Go to Solution.
12-02-2010 09:50 AM
Get in touch with your AM and they will also help you in order to submit a PER.
You can ask it for Christmas, but Santa Cisco probably has a huge backlog of PERs.
Most likely you won't be the only one to ask for this in the near future.
If you can present a good business case that can help.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-02-2010 08:35 AM
You would need to reach your account team for this kind of questions about roadmaps.
If there isn't any, you can submit a PER for this feature.
java
12-02-2010 08:54 AM
Thanks but how can I submit a PER ?
Do you have a link ?
Can I request this feature for Christmas ? ;-)
It will be the first on my wish list
Philippe
12-02-2010 09:50 AM
java
