ISD not working
Vijay Patil
Level 3
Level 3
We are facing problem with ISD calling, hen someone dials the ISD number it hit on VGW able to hear rings but then call drop..even if the dialing number is any call center number then also we hear 7-8 dialing tone & then call drop
CUCM 11.5
Cisco4321
6 Replies 6
Prashant Sharma
Hello Vijay,
can you share the call flow? Let me know if this issue is for Inbound calls or outbound?
Prassha3
Hello Prashant,
We are facing issue for outgoing ISD calls only other outgoing local & National calls are working fine  ...able to receive all calls no issue for incoming calls...
We are having CUCM 11.5 & VGW ...SIP Trunk is created in between ...
I am attaching Debug & sh run configuration...when we dial ISD number we are getting reng back tone after 7-8 ringback tone call cuts ...even we dial the International IVR number where e are hear ring back tone & not IVR prompt
Hi Vijay,
In your GW debug i see there are 4 outgoing calls to your ISP, can you confirm which call we are having issue with 3rd or 4th. They all have their own and different disconnect cause codes.
Call details.
1st Call
*Dec 24 10:44:07.324: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03AE
Calling Party Number i = 0x0181, '5006'
Called Party Number i = 0x81, '6565780000'
Cause i = 0x829F - Normal, unspecified
2nd Call
*Dec 24 10:44:56.432: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03AF
Called Party Number i = 0x81, '006565780000'
Cause i = 0x8295 - Call rejected
3rd Call
*Dec 24 10:46:46.285: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03B0
Called Party Number i = 0x81, '0006565780000'
Cause i = 0x8281 - Unallocated/unassigned number
4th Call
*Dec 24 10:48:09.451: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03B1
Called Party Number i = 0x81, '00380487385080'
Cause i = 0x8090 - Normal call clearing
Kula.
Hello, below is the actual right dialing call..end user dial various way for self check
2nd Call
If this is the correct Number then make sure you are sending it it correct format as expected by the ISP. The Provider is rejecting the call so you need to check with them on what format is expected for international calls.
HARIS_HUSSAIN
I see that calls are getting rejected due to Unallocated/unassigned number which may indicated wrong number being dialed and Normal Call Clearing.
Haris
