ISDN Cause i = 0x80D8 - Incompatible destination error
radoslav-drabik
Hi guys,
I need your help again. I have a CUCM 7.x ->Cisco 3825 (mgcp) and E1 connected to it.
All numbers are OK except some specific numbers. I use Cisco 7960 phone.
When I try to call them I got this error on the router:
Jan 31 16:15:21.606 CET: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0ACD
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0081, 'xxxxxxxxxx'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, 'xxxxxxxxxx'
Jan 31 16:15:21.686 CET: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8ACD
Jan 31 16:15:25.746 CET: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8ACD
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jan 31 16:15:38.363 CET: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0ACD
Jan 31 16:15:38.431 CET: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8ACD
Router 3825 conf.:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn negotiate-bchan
isdn bchan-number-order ascending
no cdp enable
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nte-ca
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
paolo bevilacqua
Not a router issue, complain to telco.
paolo bevilacqua
